Layer shift, crash, toolhead falls off
MaSTLab PI
(@mastlab-pi)
Hi all,
New XL user, new to Prusa, but not new to 3D printing. I have a 5T XL semi-assembled that I just got working this last weekend. I am in the process of printing plates full of PETG to assemble the enXLosure for some draft protection.
Today I had repeated failures where the extruder fell off of the carriage mid-print. In all cases, it appears that a layer shift happened randomly in the middle of the print and the carriage ran into the X rail, disengaging the locking mechanism and dropping the toolhead. I've attached a video showing it happening.
I'm at a complete loss. What the heck is this? It happened three times today, twice while I sat and watched it. If it has any bearing on the situation (belt tension, etc), I'm also getting some pretty severe audible resonance when moving at moderate speeds along the diagonal (also audible in the video). I slowed the print speed to 50% and it hasn't recurred (yet).
  • The print is PETG.
  • I'm running a 0.6mm nozzle on the tool being used throughout this print.
  • PrusaSlicer 2.7.3.
  • The printer configuration selected is "original prusa XL 5T 0.6mm" (non-input-shaper). Sliced with 0.32mm SPEED preset. The only non-default configuration is some support enforcers included in the project file for the enxlosure parts.
  • Printer is running firmware 5.1.2+13478
  • Exported as binary gcode and sent to the printer via Prusa Connect (WiFi).
Opublikowany : 04/04/2024 3:52 am
MaSTLab PI
(@mastlab-pi)
RE: Layer shift, crash, toolhead falls off
Video of crash
Opublikowany : 04/04/2024 10:10 am
From the side of the printer look along the line of docked print heads; are they all perfectly in line?  Any behind the line represent docks not sufficiently tightened in place - these are likely to be mis-registered at pickup and so at risk of dropping off.
Opublikowany : 04/04/2024 5:28 pm
MaSTLab PI
(@mastlab-pi)
It isn't an issue of the tool misregistering or being picked up incorrectly.
The carriage simply crashes into the end of the x axis, which disengages the tool locking mechanism, so the tool just gets dropped on the bed.
After chatting with prusa support, it seems the belts were over-tensioned from the factory. After correcting the belt tension, I'm running another long print to see if the problem recurs.
Opublikowany : 04/04/2024 10:48 pm
BaconFase
(@baconfase)
At around 0:15 in the video the tool is clearly going waay out of bounds, enough that the sliders contact the side gantry which pushes them leftward to unlock the tool. It shouldn't be going that far off the plate to begin with.
There was one other person that caught thing sort of thing on video but their print was going at a pretty rapid pace compared to this. Guess whatever the real cause of it was never addressed.
Same gcode file and same spot each time?
It's a known issue. The 6.0.0-alpha firmware addresses it with phase stepping but some, including myself, have had weird issues with the firmware. You're free to give it a shot if the noise bothers you that much. If you don't get issues from it then its a magical update, otherwise you can always change back.
https://github.com/prusa3d/Prusa-Firmware-Buddy/releases/tag/v6.0.0-alpha
Opublikowany : 05/04/2024 12:11 am
MaSTLab PI
(@mastlab-pi)
At around 0:03, you can hear the motion stall out. If it is due to over-tensioned belts, I'm guessing it was a case where a large acceleration along a 45 degree angle (driven by only a single motor, unlike X or Y moves) + large friction from the belt tension caused the stepper motor to stall out. The print did complete successfully when I ran at 50% speed for the remainder of the print.
Yes and no. In each case, I re-docked the tool and allowed it to re-home and resume printing. The times it repeated were at around the same location, but on different layers of the same gcode.
Thanks for the heads-up about firmware V6.0.0. I was wondering what the latest release added to the stable 5.1.2 I'm running now.
Opublikowany : 05/04/2024 1:45 am
1 ludzie polubili
kenryan
(@kenryan)
Just chiming in, I started experiencing the same exact problem.  Tool hustling along, then crashes headlong into the right rail and drops the head..  Similar to your image, it was while printing a long object at a 45 degree angle on the bed.  I recently printed a very large square, took most of the bed, and had no problem so I don't think it's the object extents per se.
I just redid some calibrations, running a small print now (lubrication tools).  I'm then going to try the same print, but with the parts positioned along the other diagonal.  I'll do a belt tension check before that, thanks @MaSTLab-PI for the suggestion.
ken
Opublikowany : 09/04/2024 2:20 am
MaSTLab PI
(@mastlab-pi)
It has not happened again for me, after about 20 hours of printing large parts (about 75% of the bed filled). However, I haven't yet tried re-printing the part that caused the original failure. If I feel like throwing a quarter roll of filament and a half day away, I may try re-running the same gcode with my re-tensioned belt.
ALSO, my X-gantry alignment was pretty off. I had probably 3 mm of play at the positive-X end of the gantry. I de- and re-tensioned the belts on the negative and positive ends of the X axis, respectively and was able to get a good X alignment with belt tension in the green. I have not tried the homing tower again, but it looked good last time the belt tension app showed me around 75-80 Hz. I will probably give it another go tomorrow to fine-tune.
Opublikowany : 09/04/2024 2:32 am
kenryan
(@kenryan)
Well my belt tension was a little loose, not much.  But I think I have a clue.
When head 1 is being used and reaching over to the right side of the bed, its harness hangs up briefly on the harness for head 2. I'm thinking that might be knocking something off when it's traveling fast.  I'll need to see if i can catch it in the act, but not sure what to do about it.
ken
Opublikowany : 09/04/2024 3:18 am
MaSTLab PI
(@mastlab-pi)
Ah - good catch. I didn't see any harness entanglement issues, just some motor cogging during fast moves, but it seems like both issues would be exacerbated by large, diagonally-oriented parts.
Opublikowany : 09/04/2024 3:26 am
hardiebotha
(@hardiebotha)
If anyone else suspects belt tensioning issues, this may help you to verify belt tension: https://belt.connect.prusa3d.com/
Open the page on your phone, which will ask for permission to use the microphone on your phone. It will provide step-by-step instructions for each printer to measure belt tension based on the frequency of the belt when pulled and released, much like a guitar tuner.
Opublikowany : 25/04/2024 12:30 pm
BillC
(@billc-2)
This happened to me today. First time.
It must be something that sometimes creeps into the gcode from Prusa Slicer. I closed the slicer, resliced the file with different object positions and it worked fine.
Opublikowany : 12/08/2024 10:07 pm
