How to clear extruder jam?
I was printing PLA and I had my first jam up in an extruder.
The jam wasn't only in the nozzle. It appears that this hole is still plugged, even with the nozzle removed.
I can't feed filament through it.
Suggestions on how to clean this out?
Veröffentlicht : 10/05/2024 11:11 am
RE: How to clear extruder jam?
I pull the nozzle out the bottom. If the jammed pieced doesn't come out with the nozzle, I then push a length of stiff wire up from the bottom through the nozzle passage to force the jam out. It's worked for me so far.
Veröffentlicht : 10/05/2024 2:51 pm
