Firmware 6.4.0 hangs and z shift
SomePerson
(@someperson)
I recently added the Prusa enclosure and switched to 5x obxidian nozzles (along with a firmware update) and it's been failed print after failed print since. At first I was convinced I'd screwed something up but fortunately I decided to dig around github before tearing the printer apart.
First issue was layer shift upwards when changing toolheads. At first I only saw it on Hueforges with .08mm layer height with a certain printhead. Then with another printhead after rearranging filaments thinking it was mechanical.  But then I did a normal .2mm layer height print with a spool join and it did the same thing. So I put the hueforge project aside and went elsewhere.
Turns out there are ~4 different bugs related to Z shift here is one
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4030
Second issue. Went to another print which was a larger one, 24 hours. At ~60% it just stopped printing, but said it was still active. Hit pause and it beeped and looked like it did something but nothing happens. Power cycle and it resumes with a layer shift, then does it again.
https://github.com/prusa3d/Prusa-Firmware-Buddy/issues/4998
On my 5T machine 6.4.0 has been a nightmare. Actually it seems every time I've updated to a 6.x firmware I've had issues, before it was the USB disconnect issue that haunted me through different versions, seems to be gone now and replaced with new ones. 5.1.2 was super solid though!
Sad because the hardware is great and it's an amazing printer when it's not failing due to some bug or another.
Time to go back a version and see what issues features 6.2.6 has!
Posted : 04/02/2026 10:26 pm
SomePerson
(@someperson)
RE: Firmware 6.4.0 hangs and z shift
And now I see its also been pulled, just my luck I updated firmware in that window!
Posted : 04/02/2026 10:37 pm
jan.d.slay
(@jan-d-slay)
The fact that firmware 6.4.0 for the XL has finally been withdrawn is an important step toward fixing bugs in the software and stopping this flood of reports about failures or malfunctions.
Writing reports has paid off, so to speak—what a satisfying feeling.
Prusa Core One - Comfortable height display
Prusa Core One - Fast & Clean Start Gcode
Prusa XL - Quick Start Gcode
Posted : 05/02/2026 6:05 am
