Filament wont load
CUKIO34
(@cukio34)
Filament wont load
Filament wont load, extruder clicks while trying to load. I tried to adjust the tension in the springs and i think i made it worse. Are there any tutorials on how to adjust the tension?
Best Answer by Brian:
The end of the screw should be flush. Although I doubt this is the issue.  If you've replaced the nozzle I suspect misalignment or blockage somewhere.
https://help.prusa3d.com/article/idler-screw-tension_177367
Napsal : 06/11/2024 11:11 pm
Brian
(@brian-12)
RE: Filament wont load
Is your nozzle plugged?
Napsal : 07/11/2024 12:47 am
CUKIO34
(@cukio34)
  • It may have been originally. But I put in a new nozzle and it still having problems. I know there's some type of method to those springs.
Napsal : 07/11/2024 12:50 am
Brian
(@brian-12)
Napsal : 07/11/2024 3:11 am
CUKIO34
(@cukio34)
Posted by: @brian-12
Thank you for the link . Just what I needed.
Napsal : 07/11/2024 3:22 am
1 lidem se líbí
Marc
 Marc
(@marc-9)
I also have that sometimes. The issue is often solved if you cut the filament again at another angle.
Napsal : 07/11/2024 8:09 am
theo
 theo
(@theo)
It happened for me as well when I tried to load PLA after used the nozzle for PETG. The set PLA temp was not sufficient to melt the PETG residue inside the nozzle. I had to load PLA as PETG to flush the PETG, then I was able to load PLA as PLA. But this mean an extra load-unload cycle. Not being able to change temperature while loading is somewhat stupid.
Napsal : 13/11/2024 1:22 pm
1 lidem se líbí
