Fan-Test failed, but all fans physically work and software pointing to random-ish failed fan(s).
Pagina 1 / 2
AcE Krystal
(@ace-krystal)
I just completed building the semi-assembled Prusa XL, nice!
I turned it on, and after flashing FW 4.7.2 it started the setup-calibration process. But during the first test (Fan test) it already failed.
Physically all fan's seem to start rotating, and then speed up and stop at the end. But the screen display's some fan's have failed. I have tested multiple things, and it seems the printer is aware when a fan is blocked (by me). And it also seems to kinda randomly see different fans fails, and previous failed fans suddenly show a green check mark.
Some things I tried :
- power cycle;
- Factory reset (soft);
- Flashing firmware 4.7.2 from USB-stick;
- Blocking fans by hand directly gives a red "x" before the test completes;
- Switched extruder 3 with extruder 1. (Extruder 3 had most problems, and this has now moved with the extruder to posistion 1. But in total all extruders seems to sometimes fail the fan test;
- Checked wiring and reseated fan plugs;
- Added more twists in the hot-end fan cable so a longer length is now twisted to potential reduce cross-talk;
None have helped so far to pass the test. My guess is that something might be wrong in the software, maybe it can't poll all 10 fan's quick enough to know every fan's status or something?
Anyone an idea what might be wrong?
Creative Engineer and 3D printing @ AcEcraft.eu
Postato : 04/11/2023 11:27 pm
AcE Krystal
(@ace-krystal)
RE: Fan-Test failed, but all fans physically work and software pointing to random-ish failed fan(s).
After spending almost 2 hours debugging I have just brute-forces my way through the test by repeatedly re-doing the test over and over until I hit the jackpot where all fan's showed green for me and I could continue the setup process. I was planning to continue the setup process manually if I could not brute-force it. But after about 12 re-try's they all where green. In total I might have tried about 40 times in the past 2 hours.
I guess this is just a setup/calibration software bug, but I still would like an more official solution for the expensive printer. 🙂
Postato : 04/11/2023 11:56 pm
1 persone hanno apprezzato
AcE Krystal
(@ace-krystal)
Update : I finished the rest of the calibration process. After the calibration process I did the Fan-Test yet an other number of times to see if it really was solved.
I'm still getting failed tests, but I'm also getting about 30% successful tests now. And it seems the I often fail at only one, sometimes 2 fans at the same time, instead of 3 or more that I had before.
An other potential cause idea : Too Low Fan RMP triggered by fresh Fan's?
If its a fail triggered thanks to low fan RPM, it could also be that new "out-of-the-box" fan's run a bit slower, maybe thanks to fresh applied oil/grease needing to find its place or excess needed to spin out before getting up to the RPM value's of a fan that ran already a few hours. If software RPM check was set based on a fan that had had already been running for some time, new fans might run slower during initial printer calibration. Just an idea why I see less fan's give errors the more I test.
I'm in contact with Prusa to try and figure this issue out.
I also saw someone else reporting the same thing here  (look at his 2nd bulled point: https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/having-a-lot-of-trouble/
Postato : 05/11/2023 2:07 am
MileHigh3Der
(@milehigh3der)
There is a whole thread about this. It seems like the most troublesome part is the print fan. I was getting all five failing. It seems the solution is to remove the print fan shroud, and then run the test. I got all mine to pass the first time I did that.  It seems that there might be some wisps of plastic stringing on the front fan that is causing it to fail. People have reported that cleaning up the shroud and putting it back on solves it. Perhaps you’ve run them so much now that it has done basically the same thing.
Postato : 05/11/2023 4:20 am
AcE Krystal
(@ace-krystal)
Interesting, for me it feels about equal failure amount between part-fan and hot-end fan. I would say a bit more hot-end fans that fail.
Where is this topic? I searched in the XL forum but did not see a topic about this yet.
I did see some trings in the part-cooling duct, but I would say they are not dragging down the fan, and blocking the airflow of these fans I though would only increase RPM on the fans. The hot-end fan might be sucking in some strings of the shielding though, and slowing it down, would need to check on that. Thanks for the tip.
Will post update if I have some news.
Postato : 05/11/2023 9:02 pm
Tim Kukulski
(@tim-kukulski)
My tests consistently failed with a random 3 of 5 heads passing on regular firmware. I retried after flashing the 5.0.1alpha and it passed on the first try.  (Not sure if it's a fix in the firmware or luck or whether the fans broke-in -- though my guess is that they tweaked the passing criteria.)
Postato : 14/11/2023 5:29 pm
Geoff
(@geoff)
This could be it. Mine failed on one of the fans multiple times on first setup, even though both fans were running. I did notice when the test finished one of the fans stopped a bit sooner than the other. Anyway the failure didn't stop me completing the rest of the setup and printing some samples. After a total of about an hour of printing I ran the fan test again and both passed. I think you are right that a brand new fan may have a slightly stiff bearing, and perhaps the test is a bit too sensitive.
Postato : 16/11/2023 4:15 pm
1Eye
 1Eye
(@1eye)
It took me 4-5 tries to get all 5 tools to clear the test on the same go. I was about to ping support and it finally stumbled through it and I moved on to the rest of the calibration. I wrote it off to the system shaking off the dust from shipping. My suggesting is to just keep trying.
Postato : 18/11/2023 5:40 am
Jason Miller
(@jason-miller)
Utenti
Fixed for me: Fan-Test failed, but all fans physically work and software pointing to random-ish failed fan(s).
I have the 2-tool XL and had the print fans failing from day one.  Went back and forth with support quite a bit (each email takes about 24 hours to get a response) and eventually was sent new fans (well, one new fan, had to wait on a second shipment a few weeks later for the second replacement).  Swapped the first replacement in and it passed the test.  When I got the second one in the mail I re-ran the tests again to confirm which one I still needed to swap out.  On that run they were BOTH failing again (firmware 5.1.0).  So I tried what MileHigh3Der said and removed the print fan shrouds - they both passed just fine then!  I can finally be rid of the annoying message before every print that I should "please calibrate"
Postato : 28/11/2023 10:13 pm
robert.e9
(@robert-e9)
I had the same problem, but after reading the replies here, I thought maybe it was just a tight fan, so I ran the rest of the calibrations, which all passed, then went back to the fans, and ran them about another three or four times until they passed.
I was a bit concerned I had over tightened the screws holding the fan down, I had to remove them to put in the nuts the hold the plastic strip, because my printer had none.  But it seems that was fine ...
Postato : 17/02/2024 12:26 am
Lady3D
(@lady3d)
Utenti
Same problem here, after 1200 hours of running, the dual-head XL's printing fan test failed. Over and over again. I checked the cables, cleaned the fan, lubricated it, but still failed. I noticed that I have overload main current (250 V instead of 230- thanks to the solar panels). After a while, the current became normal again, and ta-daa, the test was OK.
Postato : 07/06/2024 12:15 pm
AndiY82
(@andiy82)
Same issue With one of the Fans on my XL since yesterday.
Fans move free and I couldn’t find any dirt or something that could cause the problem.
then I took each tool and checked rpm at 100%. The fan which fails the test has higher rpm than the one which passes the test. 🤷
Postato : 19/08/2024 9:18 am
Renfa
(@renfa)
Utenti
This has probably been solved but after mine failed the other day, I went to tool settings after the failure and there was a setting to change from black fan to silver (which mine has) and this fixed the issue for me.
Postato : 25/04/2025 2:59 am
3 persone hanno apprezzato
Fuzzybits
(@fuzzybits)
Utenti
Thanks for mentioning - this did it for me, changing from the "black" fan to the "silver" fan in the settings.
Postato : 05/06/2025 4:57 pm
PSommerer
(@psommerer)
I had the same issue with #1, 2 and 3
Its an RPM issue.  I hit it with some compressed air to overspeed it just a tad, based on what I read here, and it still failed.
But I did the same thing to slow it down a hair and it passed...  So I held them back a bit by touching them slightly to slow them down, all fans passed.
So apparently the controller is expecting 1,000 - 2,000 and the fans are coming in at 2,011 or whatnot.   Im guessing with the fan shroud removed it sheds a bit of backpressure and reduces the rpms enough to matter.
Prusa admins should take a note and add a higher margin of error on the calibration.
Postato : 20/11/2025 10:03 pm
Hammbone
(@hammbone)
Utenti
Removing the print fan shrouds fixed my print fan calibration failures.
Postato : 02/12/2025 5:47 am
Bearded Printer
(@bearded-printer)
Utenti
Thank you! This saved me!
When I got my 2T XL set up, all I had to do was remove the fan shrouds for them to pass, but after upgrading to the 5T, suddenly the hotend fan test failed on 1, 2, and 3. I barely kept my finger in the middle of the hotend fans during their tests to hold them back just a tad and they passed!
You're a winner!
Postato : 02/01/2026 4:35 am
TRailfan2
(@trailfan2)
Utenti
Hey folks, another XL newbie here with the Print Fan fail error message after assembly of a new XL.  Updated firmware.  This error was driving me crazy.  All of the fans were clearly running fine, and I could not find any pinched cables.  I tried all of the suggestions online.  1) removing the fan shroud - didn't work. 2) loosening fan screws - didn't work, 3) changing fan setting under Tools from black to silver  - this was my first sign of hope, SOME of the fans then passed switched to silver AND removing shrouds.  But, I could never get them all to pass at the same time and different ones failed randomly after each fan test.  4) I tried putting my finger on the fans just a bit to slow them down, that didn't seem to help.  Finally, I found a solution - 5) I put a piece of painters tape over each fan outlet - without the shroud.  Note that I did not have the tape on during the high fan test, only for the slow speed test (I had to put in on quickly). Amazingly, this solved it for all fans at the same time!  So, I needed to remove shrouds, set fans to silver (mine were), and use tape over the outlet. I hope this helps someone else!   Prusa really needs to fix the fan tolerance settings.
Questo post è stato modificato 5 months fa da TRailfan2
Postato : 31/01/2026 8:43 pm
ljvollme
(@ljvollme)
Utenti
3 Things I did to get my 5T XL to pass all fans after upgrading from 2-5T:
1) Set the fan type for newer (2026 for me) print heads if they have the silver print fan. This is in settings>system>tools>print fan type
2) remove all tools' print fan shrouds
This had my 3 new tools passing about 50% of the time but never all together. the trick that got it all to pass for me that I haven't seen on any forums/reddit was:
3) up end a can of compressed air (so you shoot out some liquid co2) and blast the center of the fan where the bearing is to flash cool it, decreasing bearing resistance temporarily. all fans passed immediately after doing this.
Would be really great if Prusa could back off the sensitivity on these fan tests, I've assembled 3 XLs, single tool, dual and 5T, every single one had functional fans, every single one initially failed the test, every single one had to be bypassed by some amount of disassembly, brute force test running and air cannister use.
Postato : 26/03/2026 6:46 pm
Hemo
 Hemo
(@hemo)
Hi, I can get the fans to pass the test if i remove the shroud. Do you put the shroud back on after the pass test ?
Postato : 21/04/2026 5:44 am
Pagina 1 / 2
