Faild Printbed location during print
Noshoes
(@noshoes)
Since firmware 6.1.3 I have the problem with every print that the printbed calibration fails, from Z 10 mm the printer assumes that the printbed is 5 cm further to the left, which is not correct. As a result, the extruder crashes into the left frame and loses the print head.
I have re-sliced the model again and again, with different settings, but nothing works.
Does anyone have a solution?
Postato : 04/10/2024 8:36 am
2 persone hanno apprezzato
Faquaral
(@faquaral)
Utenti
I had a similar issue suddenly today. And when cancelling the print, tool 2 which was in use crashed into parked tool 1…
Also interested to hear if anyone has a solution
Same firmware version 6.1.3
Questo post è stato modificato 2 years fa da Faquaral
Postato : 09/10/2024 7:57 pm
1 persone hanno apprezzato
Noshoes
(@noshoes)
RE: Faild Printbed location during print
Hi, I found the Problem, the belt guiding was not correct. This caused a lot problems beginning with faild prints, a false X/Y calibration and the not working dock-position calibration.
I opened a second thread with a description in the third post (but this post is still in moderation line and not public yet)
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/dock-position-calibration-doesnt-work/#post-723982
Postato : 10/10/2024 11:47 am
Faquaral
(@faquaral)
Utenti
Interesting, thanks for your update
Personally I reverted to previous firmware 6.1.2 and the problem hasn't showed up again (yet)
Postato : 28/10/2024 11:46 am
