Can I remove the USB stick during a print?
Cadaver
(@cadaver)
Hi guys,
When I start a print from the USB stick, can I remove the stick at some point during the print? Or is it required to be inserted until the print is finished? I was hoping the entire gcode file was loaded into the printer before printing begins and the printer doesn't need the USB stick for anything after that. I would hope it was immediately put in the "ejected" state and was safe to pull after the print cycle begins. Would pulling the stick during the print cause a corruption risk?
Opublikowany : 10/07/2024 9:15 pm
No.  The file is read from the USB/SSD in real time.
Opublikowany : 10/07/2024 9:23 pm
fabnavigator
(@fabnavigator)
RE: Can I remove the USB stick during a print?
No. Please see: https://forum.prusa3d.com/forum/hardware-firmware-and-software-help/usb-stick-required-to-continue-printing/
Opublikowany : 10/07/2024 9:26 pm
Cadaver
(@cadaver)
Got it. Thanks guys!
Opublikowany : 10/07/2024 9:44 pm
