Bypass cleaning
Bryan_K
(@bryan_k)
Bypass cleaning
 So I have a problem with the automatic bed levelling, I keep having bad first layers due to the nozzle not being clean enough when probing. Cleaning the nozzle before doesn't help, because apparently the pre-print routine is designed to let filament ooze and sick to the nozzle (this happens also with fresh and dry filament). The best outcome for me is when the cleaning fails, I can then wipe it clean - it means I have to babysit the printer, but of course it beats having to restart the print - but it's a coin toss how often that happens.
 So, I know next to nothing about gcodes but I'm wondering, is there a way to bypass the automatic "nozzle cleaning" and just have the printer acts as if it had failed (extruder to the front, bed lowered, waiting for user action)?
 I'm on firmware 6.4.
This topic was modified 1 month temu by Bryan_K
Opublikowany : 30/03/2026 5:19 pm
jan.d.slay
(@jan-d-slay)
Hello
  • Open Prusa Slicer.
  • Go to “Printer” in the top menu bar.
  • Click on “Custom G-Code”.
  • Click inside the “Start G-Code” text field, then press “Ctrl + A” and “Ctrl + X”.
  • Open a text editor and press “Ctrl + V” (save a backup).
  • Now copy these lines into the empty “Start G-Code” text field:
; enable steppers
M17
; printer model check
M862.3 P "XL"
; g-code level check
M862.5 P2
; FW feature check
M862.6 P"Input shaper"
M104 T{initial_tool} S150
M117 Bett wird aufgeheizt
M190 S[first_layer_bed_temperature]
M300 S880 P120
M117 Bett aufgeheizt
M83 ; extruder relative mode
; set print area
M555 X{first_layer_print_min[0]} Y{first_layer_print_min[1]} W{(first_layer_print_max[0]) - (first_layer_print_min[0])} H{(first_layer_print_max[1]) - (first_layer_print_min[1])}
; inform about nozzle diameter
{if (is_extruder_used[0])}M862.1 T0 P{nozzle_diameter[0]} A{(filament_abrasive[0] ? 1 : 0)} F{(nozzle_high_flow[0] ? 1 : 0)}{endif}
{if (is_extruder_used[1])}M862.1 T1 P{nozzle_diameter[1]} A{(filament_abrasive[1] ? 1 : 0)} F{(nozzle_high_flow[1] ? 1 : 0)}{endif}
{if (is_extruder_used[2])}M862.1 T2 P{nozzle_diameter[2]} A{(filament_abrasive[2] ? 1 : 0)} F{(nozzle_high_flow[2] ? 1 : 0)}{endif}
{if (is_extruder_used[3])}M862.1 T3 P{nozzle_diameter[3]} A{(filament_abrasive[3] ? 1 : 0)} F{(nozzle_high_flow[3] ? 1 : 0)}{endif}
{if (is_extruder_used[4])}M862.1 T4 P{nozzle_diameter[4]} A{(filament_abrasive[4] ? 1 : 0)} F{(nozzle_high_flow[4] ? 1 : 0)}{endif}
; turn off unused heaters
{if ! is_extruder_used[0]}M104 T0 S0{endif}
{if ! is_extruder_used[1]}M104 T1 S0{endif}
{if num_extruders > 2 and ! is_extruder_used[2]}M104 T2 S0{endif}
{if num_extruders > 3 and ! is_extruder_used[3]}M104 T3 S0{endif}
{if num_extruders > 4 and ! is_extruder_used[4]}M104 T4 S0{endif}
M217 Z{max(zhop, 2.0)} ; set toolchange z hop to 2mm, or zhop variable from slicer if higher
; Home XY
G28 XY
; try picking tools used in print
G1 F{travel_speed * 60}
{if (is_extruder_used[0]) and (initial_tool != 0)}T0 S1 L0 D0{endif}
{if (is_extruder_used[1]) and (initial_tool != 1)}T1 S1 L0 D0{endif}
{if (is_extruder_used[2]) and (initial_tool != 2)}T2 S1 L0 D0{endif}
{if (is_extruder_used[3]) and (initial_tool != 3)}T3 S1 L0 D0{endif}
{if (is_extruder_used[4]) and (initial_tool != 4)}T4 S1 L0 D0{endif}
; select tool that will be used to home & MBL
T{initial_tool} S1 L0 D0
; Home Z with MBL tool
M84 E ; turn off E motor
G28 Z ; homing Z-Achse
G0 Z5 ; add Z clearance
; move to the nozzle cleanup area
G1 X{(min(((((first_layer_print_min[0] + first_layer_print_max[0]) / 2) < ((print_bed_min[0] + print_bed_max[0]) / 2)) ? (((first_layer_print_min[1] - 7) < -2) ? 70 : (min(print_bed_max[0], first_layer_print_min[0] + 32) - 32)) : (((first_layer_print_min[1] - 7) < -2) ? 260 : (min(print_bed_max[0], first_layer_print_min[0] + 32) - 32))), first_layer_print_min[0])) + 32} Y{(min((first_layer_print_min[1] - 7), first_layer_print_min[1]))} Z{5} F{(travel_speed * 60)}
M302 S155 ; lower cold extrusion limit to 155C
G1 E{-(filament_type[0] == "FLEX" ? 4 : 2)} F2400 ; retraction for nozzle cleanup
G0 Z5 F480 ; move away in Z
M107 ; turn off the fan
; MBL
G29 P1 ; invalidate mbl & probe print area
G29 P1 X30 Y0 W{(((is_extruder_used[4]) or ((is_extruder_used[3]) or (is_extruder_used[2]))) ? "300" : ((is_extruder_used[1]) ? "130" : "50"))} H20 C ; probe near purge place
G29 P3.2 ; interpolate mbl probes
G29 P3.13 ; extrapolate mbl outside probe area
G29 A ; activate mbl
G1 Z10 F720 ; move away in Z
P0 S1 L1 D0; park the tool
; set extruder temp
{if first_layer_temperature[0] > 0 and (is_extruder_used[0])}M104 T0 S{first_layer_temperature[0]}{endif}
{if first_layer_temperature[1] > 0 and (is_extruder_used[1])}M104 T1 S{first_layer_temperature[1]}{endif}
{if first_layer_temperature[2] > 0 and (is_extruder_used[2])}M104 T2 S{first_layer_temperature[2]}{endif}
{if first_layer_temperature[3] > 0 and (is_extruder_used[3])}M104 T3 S{first_layer_temperature[3]}{endif}
{if first_layer_temperature[4] > 0 and (is_extruder_used[4])}M104 T4 S{first_layer_temperature[4]}{endif}
{if (is_extruder_used[0]) and initial_tool != 0}
M591 S0 ; disable stuck detection
; purge first tool
P0 S1 L2 D0; park the tool
M109 T0 S{first_layer_temperature[0]}
T0 S1 L0 D0; pick the tool
G92 E0 ; reset extruder position
G0 X30 Y-7 Z10 F{(travel_speed * 60)} ; move close to the sheet's edge
G0 E{if is_nil(filament_multitool_ramming[0])}10{else}30{endif} X40 Z0.2 F{if is_nil(filament_multitool_ramming[0])}500{else}170{endif} ; purge while moving towards the sheet
G0 X70 E9 F800 ; continue purging and wipe the nozzle
G0 X73 Z0.05 F8000 ; wipe, move close to the bed
G0 X76 Z0.2 F8000 ; wipe, move quickly away from the bed
G1 E{-retract_length_toolchange[0]} F2400 ; retract
{e_retracted[0] = retract_length_toolchange[0]}
M104 S{(is_nil(idle_temperature[0]) ? (first_layer_temperature[0] + standby_temperature_delta) : (idle_temperature[0]))} T0
{endif}
{if (is_extruder_used[1]) and initial_tool != 1}
; purge second tool
M109 T1 S{first_layer_temperature[1]}
T1 S1 L0 D0; pick the tool
G0 X150 Y-7 Z10 F{(travel_speed * 60)} ; move close to the sheet's edge
G0 E{if is_nil(filament_multitool_ramming[1])}10{else}30{endif} X140 Z0.2 F{if is_nil(filament_multitool_ramming[1])}500{else}170{endif} ; purge while moving towards the sheet
G0 X110 E9 F800 ; continue purging and wipe the nozzle
G0 X107 Z0.05 F8000 ; wipe, move close to the bed
G0 X104 Z0.2 F8000 ; wipe, move quickly away from the bed
G1 E{-retract_length_toolchange[1]} F2400 ; retract
{e_retracted[1] = retract_length_toolchange[1]}
M104 S{(is_nil(idle_temperature[1]) ? (first_layer_temperature[1] + standby_temperature_delta) : (idle_temperature[1]))} T1
{endif}
{if (is_extruder_used[2]) and initial_tool != 2}
; purge third tool
M109 T2 S{first_layer_temperature[2]}
T2 S1 L0 D0; pick the tool
G0 X210 Y-7 Z10 F{(travel_speed * 60)} ; move close to the sheet's edge
G0 E{if is_nil(filament_multitool_ramming[2])}10{else}30{endif} X220 Z0.2 F{if is_nil(filament_multitool_ramming[2])}500{else}170{endif} ; purge while moving towards the sheet
G0 X250 E9 F800 ; continue purging and wipe the nozzle
G0 X253 Z0.05 F8000 ; wipe, move close to the bed
G0 X256 Z0.2 F8000 ; wipe, move quickly away from the bed
G1 E{-retract_length_toolchange[2]} F2400 ; retract
{e_retracted[2] = retract_length_toolchange[2]}
M104 S{(is_nil(idle_temperature[2]) ? (first_layer_temperature[2] + standby_temperature_delta) : (idle_temperature[2]))} T2
{endif}
{if (is_extruder_used[3]) and initial_tool != 3}
; purge fourth tool
M109 T3 S{first_layer_temperature[3]}
T3 S1 L0 D0; pick the tool
G0 X330 Y-7 Z10 F{(travel_speed * 60)} ; move close to the sheet's edge
G0 E{if is_nil(filament_multitool_ramming[3])}10{else}30{endif} X320 Z0.2 F{if is_nil(filament_multitool_ramming[3])}500{else}170{endif} ; purge while moving towards the sheet
G0 X290 E9 F800 ; continue purging and wipe the nozzle
G0 X287 Z0.05 F8000 ; wipe, move close to the bed
G0 X284 Z0.2 F8000 ; wipe, move quickly away from the bed
G1 E{-retract_length_toolchange[3]} F2400 ; retract
{e_retracted[3] = retract_length_toolchange[3]}
M104 S{(is_nil(idle_temperature[3]) ? (first_layer_temperature[3] + standby_temperature_delta) : (idle_temperature[3]))} T3
{endif}
{if (is_extruder_used[4]) and initial_tool != 4}
; purge fifth tool
M109 T4 S{first_layer_temperature[4]}
T4 S1 L0 D0; pick the tool
G0 X330 Y-4.5 Z10 F{(travel_speed * 60)} ; move close to the sheet's edge
G0 E{if is_nil(filament_multitool_ramming[4])}10{else}30{endif} X320 Z0.2 F{if is_nil(filament_multitool_ramming[4])}500{else}170{endif} ; purge while moving towards the sheet
G1 E{-retract_length_toolchange[4]} F2400 ; retract
{e_retracted[4] = retract_length_toolchange[4]}
M104 S{(is_nil(idle_temperature[4]) ? (first_layer_temperature[4] + standby_temperature_delta) : (idle_temperature[4]))} T4
{endif}
; purge initial tool
M109 T{initial_tool} S{first_layer_temperature[initial_tool]}
T{initial_tool} S1 L0 D0; pick the tool
G0 X{(initial_tool == 0 ? 30 : (initial_tool == 1 ? 150 : (initial_tool == 2 ? 210 : 330)))} Y{(initial_tool < 4 ? -7 : -4.5)} Z10 F{(travel_speed * 60)}
G0 E{if is_nil(filament_multitool_ramming[initial_tool])}10{else}30{endif} X{(initial_tool == 0 ? 30 : (initial_tool == 1 ? 150 : (initial_tool == 2 ? 210 : 330))) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 10)} Z0.2 F{if is_nil(filament_multitool_ramming[initial_tool])}500{else}170{endif}
G0 X{(initial_tool == 0 ? 30 : (initial_tool == 1 ? 150 : (initial_tool == 2 ? 210 : 330))) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 40)} E9 F800
G0 X{(initial_tool == 0 ? 30 : (initial_tool == 1 ? 150 : (initial_tool == 2 ? 210 : 330))) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 40) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 3)} Z{0.05} F{8000}
G0 X{(initial_tool == 0 ? 30 : (initial_tool == 1 ? 150 : (initial_tool == 2 ? 210 : 330))) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 40) + ((initial_tool == 0 or initial_tool == 2 ? 1 : -1) * 3 * 2)} Z0.2 F{8000} ; wipe, move quickly away from the bed
G1 E-{retract_length[initial_tool]} F2400 ; retract
{e_retracted[initial_tool] = retract_length[initial_tool]}
M591 R ; restore stuck detection
  • Try printing what you want again. Watch the printer and please let me know how it goes.
  • The print head is set to preheat the nozzle to 150 degrees.
  • Please preheat the print bed to your desired temperature and then let it sit for 5 minutes.
Opublikowany : 30/03/2026 6:16 pm
