After 28 hours prints get messie
JohanN
(@johann)
Postato : 17/12/2024 6:57 pm
JohanN
(@johann)
As you can see this is the second time i printed this, even a layer cameloose . At approximately 20cm the is happening. Looks it is off when it is geting higher. It is PLA and no tool change. I see that the belt is good Checked it.. and the bed feels strong.. anything i could try?
Questo post è stato modificato 1 year fa da JohanN
Postato : 17/12/2024 7:01 pm
I've not seen  this one despite some long prints - but I notice that although the print is large the actual print-sheet contact area is small. Check the first layer adhesion, if the print is warping off the bed in places it may be wobbling as the upper layers are squidged.
Postato : 17/12/2024 7:22 pm
1 persone hanno apprezzato
JohanN
(@johann)
RE: After 28 hours prints get messie
The bed is sticking great and no warping.
As you can see in this print the layers are not perfect at the beginning also..
Postato : 17/12/2024 7:36 pm
That doesn't seem to be the same part so the problems *might* have different causes ...
If you have no done so recently run through:
https://help.prusa3d.com/article/regular-printer-maintenance-xl_401237
... and also visit the belt tensioning procedure linked from there - is this the check you followed?
Postato : 17/12/2024 7:57 pm
JohanN
(@johann)
I have broken down the parts that is is not going that high..
I need to get it finished.
And good to know is that it has 150 h of print time on it..
Postato : 17/12/2024 8:14 pm
J Noordermeer
(@j-noordermeer)
here you see it again.... the print is good on the bed, belt tension is perfect.. Every time this.. i have 2 mk4 printers that do a perfect job even for a bed slinger  but this is to big..
what can this be?
Postato : 18/12/2024 1:24 pm
J Noordermeer
(@j-noordermeer)
the film
Postato : 18/12/2024 1:26 pm
Brian
(@brian-12)
I am unable to see the video, but based on the pictures I suspect a belt issue.
Check to see if your belt clamps are tight on the gantry.  You pop the Prusa XL cap off the gantry and there will be 2 belt clamps underneath.  Make sure the screws are tight.
How did you check the belt tension?  Follow this procedure.
https://help.prusa3d.com/article/adjusting-belt-tension-xl_401793
Is this in an enclosure?
Postato : 18/12/2024 1:37 pm
J Noordermeer
(@j-noordermeer)
done all that and checked with prusa support.. issue is stil there.. but seems worse on the 4th extruder..
Postato : 19/12/2024 12:01 pm
JohanN
(@johann)
Still it is not going good.. on the mk4 it looks beautiful but even after days with the helpdesk tuning calibration offset belt tension and i dant know what... How can i get this thing to work properly..
Postato : 28/12/2024 3:07 pm
JohanN
(@johann)
If look at the small print that is from the mk4... Any help will be helpful.. what i have checked all screws checked the tension of the belt.. everything looks good..
Postato : 28/12/2024 3:31 pm
