6.0.0 firmware knocks objects off bed
bbrendon
(@bbrendon)
I upgraded from 6.0.0-alpha to 6.0.0 release. I have noticed at least 3 print jobs now where the printer knocks the the object off the bed. I just had another print fail and (also downgraded firmware)  sent the exact same job to 6.0.0-alpha and it worked.
Is anyone else having this issue?
The print is with 0.6 nozzle and 0.4 layer height. No idea what the root cause is but I don't think its either of these settings as I looked through my history and I've had issues with other nozzle sizes and heights.
Napsal : 02/05/2024 4:40 am
Acht
 Acht
(@acht)
RE: 6.0.0 firmware knocks objects off bed
No, I did not. AFAIK those two versions are identical from the source code. Most likely you changed something else or something got changed somehow. I don't think the firmware is to blame here if the problem wasn't there with the alpha.
Napsal : 02/05/2024 8:03 am
Try giveng the print-sheet a thorough clean.
Napsal : 02/05/2024 7:22 pm
bbrendon
(@bbrendon)
1200 changes to the firmware doesn't seem like very identical.
Napsal : 02/05/2024 9:47 pm
Brian
(@brian-12)
I've only been running it for a few days, but I haven't lost any prints yet.
Napsal : 03/05/2024 5:08 am
1 lidem se líbí
Acht
 Acht
(@acht)
Yepp - it seems I mixed it up Release and RC3 are identical - Alpha is very different.
Sorry!
Napsal : 03/05/2024 11:39 am
