Spool Join when printing via Octo or Repetier / Define in Prusa Slicer
Prusajm
(@prusajm)
Hello,
how can I define the spools that should be joined in prusa slicer, in order to allow spool join ?
I know, it is possible when printing from local USB stick !
When using octoprint or repetier server, I have not found a way to select which spools should join, neither while printing at the printer display, nor when slicing using prusa slicer..
Opublikowany : 11/01/2024 1:17 pm
1 ludzie polubili
IanY
 IanY
(@iany)
RE: Spool Join when printing via Octo or Repetier / Define in Prusa Slicer
I am also wondering if this will work as well.  Did you ever find an answer?
Opublikowany : 10/06/2024 7:33 pm
Hemo
 Hemo
(@hemo)
This would be great as i mainly use Octoprint.
Opublikowany : 16/06/2024 12:48 am
