Side sensor collets
Asus1357
(@asus1357)
Side sensor collets
I am not too familiar with bowden parts so I ask the community for advice (do not want to sit on the phone for that long for this simple question.)
I need to replace a couple of the collets on my side sensor (yes I got a bit to aggressive and pushed them out and damaged them putting them back in.)
Are these special collets? or just regular ones?
Thanks
Opublikowany : 11/11/2024 2:19 pm
Acht
 Acht
(@acht)
RE: Side sensor collets
To clarify - you are looking for this part - right?
https://www.prusa3d.com/en/product/heatsink-collet/?_gl=1*erdkkp*_ga*ODQyNTU5OTk3LjE3Mjc5NTI1MjY.*_ga_3HK7B7RT5V*MTczMTMzNzEyOS4yNC4xLjE3MzEzMzkxMDUuNTYuMC4w
Opublikowany : 11/11/2024 3:32 pm
Asus1357
(@asus1357)
That is my problem. Yes it look like that but it is not for the hot end. I require ones for the side sensor and well I hate to assume they are the same?  I assume they are the same though, just the online ones at amazon have a clip. Not sure if that makes a difference. If I require ones like your link has I  do not see them on amazon.
thanks
Opublikowany : 11/11/2024 4:06 pm
John Paul
(@john-paul)
They're likely standard Bowden collets, but it's best to check the diameter and compatibility with your printer. Most 3D printer suppliers carry replacements.
Posted by: @asus1357
Thanks
Opublikowany : 26/11/2024 9:17 am
CastIronCoffee
(@castironcoffee)
Did you figure this out? I have a similar problem. The extra hotend collets I had for E3D are bigger and don't really fit the side sensor.
Opublikowany : 19/12/2024 9:14 pm
Asus1357
(@asus1357)
No I did not.  I just squeezed them in the best I could. I ordered some that look like they might work but we had a postal strike (Canada) and well it is in the mail (somewhere)
Opublikowany : 21/12/2024 5:31 am
