PSA: Prusa Connect control may move without homing and collide with docked tools
It seems that clicking on the print bed to move the toolchanger in the Prusa Connect/Control UI may not ensure that the printer has homed since power on. For me, the sequence of events was as follows:
- Newly-assembled semi-assembled 5-tool.
- Printer previously updated to 5.1.0 fw.
- The printer has gone through all first run tests and calibrations, but nothing has been printed yet.
- Turn on the printer.
- Use LCD Control menu to pick up tool 1.
- Use LCD Control menu to "Park current tool".
- Turn off printer.
- Turn on printer.
- Set up WiFi using ini file created by prusaslicer.
- Set up Prusa Connect.
- Using Control tab in prusa connect, click roughly the centre of the print bed to move the print head there.
- The printer has not homed since power on, and does not home as a consequence of the previous step. The toolchanger head is currently just in front of tool 1 which was previously parked.
- The toolchanger moves further towards the back of the printer and stars grinding with force from left to right across the main locking forks sticking out of tools 1 and 2.
I have reported this to support.
Note: Image inline below may be cropped, click to see the full image.
Respondido : 28/11/2023 8:33 pm
