Poor XL 5T 0.6mm nozzle PETG printing with InputShaper Version of Prusaslicer
Simple3D
(@simple3d)
I have an early XL 5T that was shipped with 0.6mm nozzles. I print mostly PETG. The "Original Prusa XL 5T 0.6 Nozzle" printer profile works great. The "Original Prusa XL 5T Input Shaper 0.6 Nozzle" DOES NOT!  Prints with support usually fail. It's as if the nozzle can't heat the PETG fast enough. It gets poor layer adhesion. I know I could slow things down or up the nozzle temp, but it would be nice if the official profile worked. Anyone else have these issues? or has everyone switched to 0.4mm nozzles?
Opublikowany : 22/03/2025 1:55 am
Mine too came with 0.6mm nozzles 'though now I have 0.4mm nozzles on two of the toolheads but those don't get a lot of use except for print-in-place mechanisms and multicolour text/graticule labelling.
I go to a lot of trouble to avoid designing supported prints but where necessary I generally try to make it possible to support with a different material.
I rarely use input shaper, most of my prints are functional, especially those in PETG so for me interlayer adhesion is usually more important.  You are using grid infill; this is frequently problematic with polyamides, try using cubic fill.
Opublikowany : 22/03/2025 2:48 am
Pablo
(@pablo-3)
RE: Poor XL 5T 0.6mm nozzle PETG printing with InputShaper Version of Prusaslicer
Tengo el mismo problema, petg con 0.6mm en la XL que vienen todas de 0.4mm. Lo hice para bajar tiempos, impresiones de 2 días en 0.6, que pasan a 5 días en 0.4mm.
Se me han estropeado 5 impresiones después del primer día.
Con 0.4mm imprime bien, a 250 °C, pero con 0.6mm a 250°C queda muy áspero (como con burbujas, y no es el filamento ya que es e mismo usado con 0.4mm), a 240°C lo mismo pero menos áspero,  recién con 230°C comienza a quedar bien pero se me han despegado capas.
Otro tema es que el tubo de teflón con la primer impresión larga ha quedado blanco (en lugar de medio transparente). Fue dañado por el continúe pasar del filamento. Eso no está bien.
La misma pregunta que Simple3D, alguien tiene un perfil correcto?
Opublikowany : 19/08/2025 6:25 pm
Bubbles suggest your filament may be wet - the effect is always worse with larger nozzles; very long prints may require a drybox for success.
Interlayer adhesion can be improved by slowing the print - some of the 'speed' type profiles are intended for impatient printers of trinkets - for practical parts always take a little more time.
The tubes do wear with use; especially if you are printing abrasive filaments.  You might extend their life by rotating them 180° but eventually they have to be replaced.
Opublikowany : 19/08/2025 11:23 pm
Pablo
(@pablo-3)
Garcias Deim por la respuesta.
De todas formas te tengo que comentar para que veas lo extraño.
El filamento es nuevo y solo tengo problemas con nozzle de 0.6 arriba de los 240 y mas a los 250°C. En 230°C no tengo problema. Lo mismo si con el mismo filamento imprimo a 250°C con el nozzle de 0.4mm.
Lo de la caja soy consiente que ayudaría, pero nunca había tenido problemas con el petg. Este es Creality negro, no se si sirve al caso.
Estoy imprimiendo muy lento para que quede bien y no exigir a la impresora que es nueva nueva, no tiene ni 10 kilos impresos. Lo mismo aplica al tubo, que es nuevo y al ser el cabezal 5 no debe llegar ni a 2kilos de uso y solo con pla, primera vez petg. Y buena idea girarlos 180 grados. Muchas Gracias.
Opublikowany : 19/08/2025 11:58 pm
So: very light use and the tube goes cloudy after one material change? - You might have a spool of deteriorating or otherwise dusty filament.  Blow some compressed air through the tube and see if dust comes out ... if so, find some way to clean the filament.
Opublikowany : 20/08/2025 8:02 pm
