Park current tool during pause and play some tones
Randy Ubillos
(@randy-ubillos)
Miembro
For a current project I need to pause the print at a point in the middle of the  job. In order to park the current tool before the pause and pick it up after, I replaced the "Pause Print G-code" with:
G1 F{min(350.0, travel_speed)*60} ; Set fast travel speed
P0 S1 ;  Park the current tool
M300 S500 P500 ; The next 7 lines play three notes as an alert
G4 P300
M300 S300 P500
G4 P300
M300 S500 P500
M601 ; Initiate printer pause
G4 P100 ; Wait 100ms
T{current_extruder} S1 L0 D0 ; Pick up the current tool
The trick here is the G4 P100 after the M601. This isn't documented as being needed, but without it the command to pick up the current tool at the end is not executed. Took a bit of investigation to figure out what was going on, thought I'd pass it along in case anyone else needs this.
Respondido : 29/12/2023 10:40 pm
6 les gusta
deckar01
(@deckar01)
RE: Park current tool during pause and play some tones
Thank you for sharing this! I have been tending to a batch of parts this weekend that have two pauses where I insert jigs and I immediately reprint when complete. (I use support jigs that I tape in place to save a significant amount of time and waste and produce even cleaner overhangs than soluble interfaces). I was getting a significant amount oozing when the nozzle paused in the air, which caused the first few cm after resuming to not extrude. Parking should be the default behavior for the pause gcode on the XL.
Rather than beeping I use this script to sends push notifications to my mobile device when the machine needs attention:
https://gist.github.com/deckar01/7099fc92865c6173d8c9e04bd32015d5
Respondido : 27/05/2024 3:17 pm
Randy Ubillos
(@randy-ubillos)
Miembro
For reference, here's the code without the tones:
Respondido : 20/07/2024 2:46 am
1 les gusta
HighTechRedNeck
(@hightechredneck)
Miembro
This was EXACTLY what I was looking for today and works perfectly.  Thanks!
Respondido : 18/09/2024 3:35 am
Johannes
(@johannes-5)
Miembro
Our XL crashes with a watchdog reset error after resuming from the pause. Any ideas?
Respondido : 07/01/2025 9:06 am
Johannes
(@johannes-5)
Miembro
I've got it working now, I think the crash is caused when the print is immediately resumed. When I wait a few minutes before resuming it does not crash.
Respondido : 08/01/2025 9:48 am
mhg
 mhg
(@mhg-2)
Miembro
Posted by: @randy-ubillos
Unfortunately this doesn't work on my XL with FW version 6.2.0+8816. After the pause it fails to pickup the parked tool before continuing 🙁 . Any ideas on what needs to be tweaked for 6.2.0?
Respondido : 21/02/2025 5:35 pm
mhg
 mhg
(@mhg-2)
Miembro
After updating FW to 6.2.1, the code is working fine 😀 ! Looks like the problem was related to the FW version.
Respondido : 24/02/2025 6:58 pm
