Orca Slicer for XL
Scisok
(@scisok)
Orca Slicer for XL
There is now a profile in Orca Slicer for the single tool Prusa XL.  It will not support multiple extruders yet.  If you send a multi filament gcode it will try to do a filament change on the 1st extruder.  Hopefully there will be a multi extruder version soon.
Opublikowany : 28/07/2024 1:08 pm
Ro3Deee
(@ro3deee)
RE: Orca Slicer for XL
The dev branch of Orcaslicer has support for multiple tools and multiple nozzle sizes. Here is a video :
Opublikowany : 28/07/2024 2:49 pm
Scisok
(@scisok)
It is so nice to easily do calibration tests with Orca Slicer. With 5 heads I can easily check different filaments by just changing them on the machine LCD without reslicing.
Opublikowany : 28/07/2024 5:54 pm
Cotano
(@cotano)
That would save a lot of time.
Opublikowany : 30/07/2024 4:19 pm
Pe3d
 Pe3d
(@pe3d)
There ist now a Dev Version of Orca slicer for 5T
https://github.com/SoftFever/OrcaSlicer/releases/tag/nightly-builds
Opublikowany : 02/09/2024 10:45 am
Scisok
(@scisok)
Orcaslicer 2.2 beta with multi tool support is now available on GitHub.  It looks to be awesome with multiple nozzle size capabilities.  Please share your experiences with this version.
Opublikowany : 16/09/2024 11:25 am
Rof
 Rof
(@rof)
Super excited for this, i tried a few prints using the preloaded config. Was able to connect and print with the head currently loaded, but any time I added a head change I get stuck in a loop of "Please remove filament from filament sensor" then get told to load the filament back lol. It wont seem to trigger the head swap..is there a config/setup step I missed?
thanks in advance!
Opublikowany : 24/09/2024 6:15 pm
Scisok
(@scisok)
It sounds like you didn’t load the Prusa XL 5T printer.  If you load the Prusa XL it will behave as you said.  I finally got around adding filament profiles from Prusaslicer (manually).  The 5T is great.  Did  up some PETG/TPU prints.  Very nice. So far only a few bugs but so nice to use one slicer for all my printers.
Opublikowany : 14/10/2024 1:50 am
Scisok
(@scisok)
Orca 2.2 is released with support for the XL 5T!  There are not many filament profiles yet.
Opublikowany : 30/10/2024 9:07 pm
1 ludzie polubili
John Gibson
(@john-gibson)
Is there an option for the multi - material settings to have the supports be printed out of a different material? Am I looking in the wrong section?
Opublikowany : 23/01/2025 9:33 pm
ludodg
(@ludodg)
You can now choose the Prusa XL 5T  (5heads) and then  adapt it to two heads
In the Printer-tab, click on Edit Preset
Then choose MULTIMATERIAL,
Extruders: 2
and save the new profile on a new name.
Opublikowany : 08/04/2025 9:43 pm
mar-gt
(@mar-gt)
But if I need to print with 4 heads (pla) and with the 5 head PETG - that is not possilble?
Opublikowany : 16/04/2025 10:45 am
Thomas
(@thomas-21)
Hi did you get any response of working with orca slicer and Prusa XL 5t ?
When i try to do some Calibration PA , and slice this calibration, the Prusa XL Print no problem.
But no changed in PA Values or something, it it one print with 1 PA setting.
i want to do like in this Video but i get not this result from the video
Opublikowany : 21/07/2025 1:52 pm
