Inadequate dock/nozzle clearance - versatility design flaw.
Russell Pirlo
(@russell-pirlo)
I use some 'exotic' nozzles for my work, which enable specific functionalities. Specifically, I use these airbrush nozzles which are longer with a narrower profile. There is very little clearance between the nozzle tip and the t-slot bar that holds the docks, not enough for these nozzles to be used (I need about 4mm more clearance).  I need to use these nozzles, so I'm looking into designing some replacement metal frames. I would like to suggest a frame design that is adjustable/slotted so that other nozzles can be used.
https://www.amazon.com/Archetype-Brass-Nozzle-Stainless-Steel/dp/B09RHNW3BY
https://photos.app.goo.gl/mGD8f3rWAt5GiT7p7
Publié : 06/06/2024 6:21 pm
