Y axis failure
jacques.d.tessier
(@jacques-d-tessier)
Y axis failure
I just received the printer and finished installing the enclosure. When I tried the y-axis test, it moved forward and hit the end, and the printer tried several times to keep moving forward.
I tried different belt tensions based on different posts, and I do not see anything interfering with the belts. It seems there are no sensors to stop the head from moving forward.
Opublikowany : 11/01/2025 8:20 pm
For build/assembly issues the first place to go for help is Prusa support via chat.  They will first want the serial number of the device with issues.
Opublikowany : 12/01/2025 2:52 am
jacques.d.tessier
RE: Y axis failure
Thanks
I will give it a try
Opublikowany : 12/01/2025 2:56 am
jacques.d.tessier
RE: Y axis failure
just an update the belt did not have the right tension. when I fixed that I was able to print.
Opublikowany : 30/01/2025 9:17 pm
