Print is not aligned and shifted
I just started a new print with my dual head printer. I noticed a strange behavior. The printer starts to layer shift. As the picture shows, sometimes it‘s shifted left and right. I‘m not sure why this is happening?
Best Answer by xenon:
looks like the pulleys on the xy steppers are not quite tight. check the grub screws
Download our 3D Print Cost Calculator Tool:
https://andreas-reitberger.de/en/3d-druckkosten-kalkulator/
RE: Print is not aligned and shifted
Thanks for the hint, I‘ll do so and report back 🙂
This was the solution, thank you!
