Nozel Heater Test failing on Extruder 1 - Initial Setup
gcarmich
(@gcarmich)
I have assembled my XL.  I'm running through the initial tests and calibration.
During Nozzel Heater Test, the unit only seems to test and pass Extruder 2.
The first two test on extruder 1 has x next to them.  Extruder 1 is never removed from the parked position.
Should Extruder 1 be tested out of the parked position?
How should I troubleshoot?
I'm running latest firmware.
Postato : 31/10/2024 2:04 pm
gcarmich
(@gcarmich)
RE: Nozel Heater Test failing on Extruder 1 - Initial Setup
I swapped the data cable between extruders and pattern reversed and extruder 1 passed and extruder 2 failed.
I switched back to original configuration and re-plugged the extruder data connector on the board and problem still occurs.
To me, this indicates that the issue is not in the extruders.
It is probably a board issue.
I'm going to contact Prusa.
Postato : 31/10/2024 6:21 pm
