Always doing Home XY First operation between tool changes
Ninju
(@ninju)
Hello fellow printers
Doing some initial prints with my XL 5TH and I noticed that it always does a home XY between tool changes?
Is this normal because it seems to add 20 seconds to every tool change 🤔
TIA
Napsal : 08/11/2024 7:59 am
Brian
(@brian-12)
RE: Always doing Home XY First operation between tool changes
No it's not normal.  Mine does not do this.
It only homes at the start of a print, or if it's been sitting idle for awhile.
Napsal : 08/11/2024 2:13 pm
Ninju
(@ninju)
Thanks for your quick reply
I see this other posting where somebody was having the same issue
https://forum.prusa3d.com/forum/original-prusa-xl-tool-changer-hardware-firmware-and-software-help/tool-head-2-keeps-homing-x-y-axis-every-layer-its-used/
I tried their resolution (adjusting the crash sensitivity) and it did not help 🙂
What is the process for engaging company support as I have paid for support and I've got other issues?
Napsal : 08/11/2024 3:05 pm
Use prusachat
Napsal : 08/11/2024 3:29 pm
Ninju
(@ninju)
Support narrowed the problem to a loose screw within the Tool Changer (Prusa Semi-assembled, Section 5, Step 5 https://help.prusa3d.com/guide/5-tool-changer-assembly_504693#504929) thanks for the help everyone!
Napsal : 09/11/2024 3:49 am
2 lidem se líbí
