use a logo image as a printing stamp
hello everyone,
lets assume I am printing a white rectangle. then I have a vector graphic (or any other image format) in 2 colors that I would like to use as a "stamp" to use it to incorporate it into my white rectangle as a color change setting. as if I would apply a sticker basically. and then associate color 1 with extruder 1 and color 2 with extruder 2 ... and the white would be extruder 3.
how do I best approach this?
thanks for your help!
Steff
Posted : 08/10/2024 6:10 pm
You can load an SVG file as a modifier or a negative volume and treat it accordingly. Select object, right click, mouse over Add Modifier, select SVG - once placed you can allocate a different extruder to it.
Posted : 09/10/2024 2:31 am
