File or Drive error mid print.
Revel
(@revel)
I am starting to get File or Drive errors mid print. I'm always printing via Prusa Connect - Upload and Print.
This has happened on multiple setups including converters to SD Cards.
Reseating doesn't work. Same file on another drive makes it so I can't resume.
I lost my original XL usb Drive long ago.  I can't format anything in Fat32 in Windows11. Its only allowing exFat and NTFS. How can I do a Fat32? Internets says exFat and Fat32 are not the same. Need help there.
Also any other advice is much appriciated. Been using my setup for a long time mostly just fine and now this is popping up and its been very wasteful of PETG. I don't know whats causing it or how to fix this issue.
Napsal : 17/03/2025 5:13 pm
