Inverted Extruder Sensors
Chris
(@chris-43)
I've got all five extruder sensors acting up.
They show as "ON" when unplugged and plugged in with NO filament present.
They show as "OFF" when plugged in and filament is present.
The result is that I must load the extruder, lift the flap, and unplug the sensor every time I switch the filament.  This is not due to sensor "placement" or plug orientation, since unplugging the sensor results in the "ON" bit being flipped.
So, this must be a bug.  Anyone familiar with this issue?
Veröffentlicht : 24/04/2025 7:40 pm
Chris
(@chris-43)
RE: Inverted Extruder Sensors
The odd thing here is I've had this firmware installed for a while, and merely left it turned off for a month or two.
Veröffentlicht : 24/04/2025 7:41 pm
