[Solved] After 2 to 5 upgrade, New Toolheads not turning on
Ian M Keller
(@ian-m-keller)
I just did an upgrade from 2 to 5 toolheads, but the three new toolheads are not turning on. No lights on them and they are not showing up in the menu or to calibrate. I tested the PSU and the output onto the card where the 3 new toolheads are plugged in and it showed they are getting power. Not sure what else to check or what I could have done wrong.
Napsal : 17/09/2024 4:07 am
mvikman
(@mvikman)
If the PSU is providing 24V to the board, I would check that the board is seated properly in the connector and check the cable connectors on the board and toolhead.
If all those are ok, then maybe the board is bad.
Napsal : 17/09/2024 9:34 pm
