Additional single tool
Elchschmied
(@elchschmied-2)
Utenti
Hello, is it possible to and a single toolhead to a dual Header XL? Is the third power supply needed for 3 toolheads?
Thank you
Postato : 10/04/2024 4:11 pm
3 persone hanno apprezzato
Cbreier
(@cbreier)
Utenti
RE: Additional single tool
I am looking for the same information. I have two 2 heads and would like to add a 3rd. Not sure I have many uses for 5 heads but 3 seems to be a sweet spot for me.
Postato : 27/08/2024 9:43 pm
Pierre VM
(@pierre-vm)
Utenti
I have the same question.
Postato : 11/03/2025 10:37 pm
Ruhr3D
(@ruhr3d)
Utenti
Aloha 🙂
Does anyone have an answer yet? I have a Prusa XL with two heads and would like a third head. So far I've only found one post in a German forum that says it won't work. But I haven't found anything about whether it really works or not.
Chris
Postato : 26/06/2025 7:05 am
I doubt anyone outside Prusa has tried it.
The maths suggest the addition of a third toolhead without an additional power supply puts the power  requirements into a grey zone.  Probably you would get away with it using PLA and regular nozzles but some idiot would then try three high temperature filaments or large nozzles triggering a catastrophically high power demand and consequent failures.
Postato : 26/06/2025 1:00 pm
Ruhr3D
(@ruhr3d)
Utenti
Posted by: @diem
Aha! That sounds logical. Of course, with three heads there is also another power supply unit in addition to the circuit board.
Thanks for your answer 🙂
Chris
Postato : 26/06/2025 2:20 pm
