Nextruder cables falling forward.
Steve
(@steve-4)
Has anybody figured out how to get the Nextruder cables and filament tubes to lean back (like they are supposed to)?  Mine fall forward enough to cause a Nextruder (when moved to the right side of the bed) to snag on the cables of the parked Nextruder.  It is causing prints to fail.
I tried using a spring to pull back the cables, but I couldn't find one weak enough.
Senior Life member of IEEE.
Postato : 12/01/2025 11:40 pm
Steve
(@steve-4)
RE: Nextruder cables falling forward.
Here is a picture.  Perhaps someone can tell me if the plastic straps are on backwards.  There is no indication of front or back on these straps.
Postato : 21/06/2025 2:18 pm
The straps are correctly oriented and the angles are only slightly different from mine - but check you have pulled the flexible plates upwards as far as the keyhole openings allow -
Step 42 on: https://help.prusa3d.com/guide/6-extruder-accessories-assembly_507533#508626
Adjacent cable bundles will touch in certain positions but should not engage - slide adjacent bundle tidy clips up and down a fraction so they miss each other.
I tried dropping a straight line onto your picture but the angles are such that I cannot rule out barrel distortion in the image, so:
From the side, look along the line of docks and ensure they are all exactly in line - a 1mm error could cause occasional toolhead drop-offs.   Ensure they are all installed firmly, you have to get the mounting bolt *very* tight.
See steps 9 and 10 on:  https://help.prusa3d.com/guide/6-extruder-accessories-assembly_507533#507653
Postato : 21/06/2025 3:51 pm
ntdesign
(@ntdesign)
I had this issue on tools 4&5. This solved it:
https://www.printables.com/model/664544-prusa-xl-series-cable-protecting-toolbase-clip-mus
Postato : 27/06/2025 7:29 am
