Printing in different colour without re-slicing?
Onno
 Onno
(@onno)
I wonder if I can print a certain print that is stored on my SL1S without having to re-slice it if I want to use a different colour. I intend to use the same kind of resin (Prusa tough)
Best Answer by Diem:
If the printing requirements are the same - read the label - then yes, you can use the same code.  If they differ, re-slice.
Pigments do occasionally change the parameters - quite often clear behaves differently for example and dark colours may differ from white but read the label, it can save a lot of work.
Napsal : 21/11/2023 11:49 pm
Napsal : 22/11/2023 3:00 pm
1 lidem se líbí
Onno
 Onno
(@onno)
RE: Printing in different colour without re-slicing?
I forgot about checking the profiles. Thanks for reminding me.
Napsal : 23/11/2023 4:56 pm
