[Rozwiązany] SL1 Support for Prusa Connect?
ManyUCL
(@manyucl)
Sooo,
I have the option in Prusa Connect to add the sl1 printer to connect:
The guide in connect:
If the Original Prusa SL1 printer is connected to the internet you could add a printer to Prusa Connect from a menu Settings > Network > Prusa Connect > Add printer to Connect. (This menu does not exist, at least not in the newest firmware 1.7.2 is there a beta version somewhere?)
The guide in connect second line:
Scan the QR code or type the Code manually below.
(I tried to enter the prusalink login qrcode, it fails and says this: "Registration for given code not found")
I must be missing something here, i can find no other mension of a code...
Hope someone can clarify... =)
Best Answer by Alfred:
Hello,
thake the Beta Firmware for Prusa Connect Support:
https://github.com/prusa3d/Prusa-Firmware-SL1/releases/tag/1.8.0-beta.0
Opublikowany : 21/06/2024 1:08 pm
Alfred
(@alfred-3)
RE: SL1 Support for Prusa Connect?
Hello,
Opublikowany : 22/06/2024 6:06 pm
ManyUCL
(@manyucl)
Thanks, that did the trick.. 🙂
Opublikowany : 25/06/2024 9:17 am
