How to reduce the standard "Object Elevation" value of 5mm while having pads bellow the object?
Victor Sorensen
(@victor-sorensen)
Hello,
I was printing some small objects and I saw that most of the layers were destinated for the support pillars. I tried to reduce its height, in order to reduce the printing time, and I saw that the lowest acceptable number of the "object elevation" parameter was 5mm, for pads below the object. Is there a reason for it? and Is there a way to reduce this value, while maintaining the pads below the object?
Thank you in advance,
Victor
Publié : 08/08/2022 12:10 pm
