Firmware 1.3.3 to 1.4.0 fails
AMG
 AMG
(@amg-2)
i have a problem updating my SL1 to firmware 1.4.0. Tried it via W-Lan, download works, machine is rebooting, 30 seconds blacj screen with orange blinking button, then the interface says 1.3.3. No error message.
Installation via USB Stick, W-Lan disabled, same problem.
Any help is greatly appreciated,
Best regards
Axel
Respondido : 06/08/2020 9:12 am
Jakub Dolezal
(@jakub-dolezal)
Miembro Admin
RE: Firmware 1.3.3 to 1.4.0 fails
Hi Axel,
can you please go to the Settings -> Advanced settings -> Save Logs to USB, save them to a USB drive and send it to the [email protected]? Mention my name in the email, I will check them out and let you know 😉
Assembly manuals
/ Knowledge Base
Respondido : 06/08/2020 11:21 am
1 les gusta
AMG
 AMG
(@amg-2)
@jakub-d
"You've got mail" 🙂
Respondido : 06/08/2020 1:19 pm
patmis67
(@patmis67)
Hello, everyone. I have the same problem:
My SL1 has firmware 1.3.0 and I want to upgrade to 1.4.1. I have tried everything:
The online update doesn't find new firmware. The local update via USB stick does not work either. It loads and at 100% the message appears that the update did not work.
I am grateful for every solution suggestion.
Respondido : 19/08/2020 1:43 pm
utdsk
(@utdsk)
Posted by: @patrick-m33
I have the same issue. I also tried doing a factory reset and then updating again, but it always fails after loading the new firmware.
Best regards,
Alex
Respondido : 25/08/2020 12:09 pm
