Extra vat and build platform
maeriksen
(@maeriksen)
So I want to have a vat for clear resin and one for opaque ones. I just ordered the two, and was wondering if anyone else has had experience in this direction, including storage of a vat out of rotation.
Also, I’m wondering if an additional build platform would be usable with the same calibration as the original so that I can clean and cure while the next print is underway. Would probably require tight manufacturing tolerances. I wouldn’t want to crack the LCD on my new toy professional work machine that I definitely need.
Napsal : 26/07/2019 9:22 am
JohnF
(@johnf)
RE: Extra vat and build platform
I have found that the resin gets under the edge of the vat and could potentially color transparent resin. I have a second vat that I am using only for clear for this purpose. I cleaned it with soap and water and just have it stored on its side to avoid dust collecting on it.
As for the build plate - I also have a spare - you cannot swap it out without recalibrating.  The print fails, unfortunately.
Napsal : 04/09/2019 12:51 am
Brettcnc
(@brettcnc)
http://ebay.us/dRorHX?cmpnId=5338273189
We made some build platforms...
Napsal : 31/01/2020 8:47 am
crullier
(@crullier)
Posted by: @john-f29
.... I also have a spare - you cannot swap it out without recalibrating.  The print fails, unfortunately.
That sucks, I was afraid of this. I wish that maybe we didn't have to go through the vat leveling at least - just the plate calibration. Is that possible?
Napsal : 11/02/2020 4:49 am
