Can you change the calibration tilt step size?
michael.a24
(@michael-a24)
When calibrating my SL1S, one step is a little too low to be perfectly aligned with the bottom of the resin tank, and the next step is a little too high.  So I either end up with layers too thick at the front of the build plate and too thin to stick to the build plate at the back, or vice versa.  In either case, there's only a small portion of the build plate where I can place objects and not have the print fail.  Is it possible to change the step size so I can split the difference and get an actual level tank, or adjust the starting tilt position so I can end up where I need to be?
Publié : 25/11/2022 9:17 pm
