Will an ultrasonic cleaner damage the print bed?
k
 k
(@kotgc)
Hi 😊 , I don't have the CW1 yet, so I'm using an ultrasonic cleaner.
  1. I'm wondering if I can simply dunk the whole print bed with print in the ultra sonic cleaner?
  2. I wonder if the print will automatically come off the print bed?
  3. Would the print bed or print bed paint/surface be damaged?
  4. Anyone tried this before?
Opublikowany : 17/02/2020 8:09 am
momeedees
(@momeedees)
RE: Will an ultrasonic cleaner damage the print bed?
+1
Also interested in any info about the VAT/Tank to be cleaned in an ultrasonic bath (with water and dishwash).
Any experiences shared, appreciated.
Opublikowany : 18/02/2020 4:51 pm
m.neeser@bluemail.ch
(@m-neeserbluemail-ch)
Posted by: @kotgc
Don‘t worry about the print bed: this is anodized aluminium and will not be damaged by an ultrasonc cleaner containg IMS or ethanol nor any other mild solvents.
Opublikowany : 18/02/2020 7:45 pm
Posted by: @kotgc
Don‘t worry about the print bed: this is anodized aluminium and will not be damaged by an ultrasonc cleaner containing IMS or ethanol or any other mild solvents.
Opublikowany : 18/02/2020 7:46 pm
k
 k
(@kotgc)
Thanks.
I'm using methylated spirits (denatured alcohol) as the cleaning liquid.
It's 25% the cost of the recommended 3D print resin cleaning IPA (isopropyl alcohol).
This post was modified 6 years temu by k
Opublikowany : 19/02/2020 2:09 am
Area51
(@area51)
Posted by: @kotgc
Thanks.
My experience with denatured alcohol is that it leaves a thin white film after evaporation - properly the additives to make it undrinkable. Do you wash in water to avoid that film?
Opublikowany : 19/02/2020 2:40 am
k
 k
(@kotgc)
@area51
I'm about to do my first 3D print.
Opublikowany : 19/02/2020 4:51 am
Posted by: @area51
Posted by: @kotgc
Thanks.
I'm using denaturated alcohol (ethanol / methilated spirits) too and can sometimes find white spots on my casts after washing. But this mainly happens when I let the alcohol evaporate. When blowing it off with air (airbrush pistol) this will not happen.
Some resins seem more prone to the white spots, others less: The Prusa Tough Gray resin doesn't show any white marks at all, even when I let the alcohol evaporate. The transparent resin is more delicate.
Give the parts a final rinse in clean alcohol and keep water off the prints. The alcohol/resin mix combined with water produces a whitish slurry. This is what probably happens
Opublikowany : 19/02/2020 8:54 am
Area51
(@area51)
@m-neeser
I will try denaturated alcohol as this is a lot cheaper and more easy to come by. Maybe a first clean dip in denaturated alcohol to clean for uncured resin and then a final bath in isopropyl to clean off denaturated alcohol before drying. That would make the expensive isopropyl alcohol last 😀
Opublikowany : 20/02/2020 12:17 am
k
 k
(@kotgc)
Nice 😉
I will try to full test and post results if bad.
Opublikowany : 20/02/2020 12:24 am
