Resin Odor
debra.k
(@debra-k)
Resin Odor
Just finished building my SL-1.  It went together very easily, nice jog Prusa!
My question is the odor associated with printing.  Does the SL-1's filters diminish it enough that I can use the printer in my home office?  I had a Peopoly Moai and had to use it in my basement because of the resin odor.
Thanks
Debra
Napsal : 27/10/2019 1:08 pm
World Terrain Factory
(@world-terrain-factory)
RE: Resin Odor
The filter does help diminish the smell while printing but not where it will be unnoticeable.   I find that the greatest source of odor is spread once the lid is open and you are handling the finished model for post-processing.  Even if you were to quickly move the part elsewhere to post-process, the odor will still permeate the area.
I would not recommend that you ever use a resin printer inside any home area.  Even though I have mine in my garage workshop (which has ventilation to the outside) the smell still lingers and travels into the room connecting to the garage.
Napsal : 27/10/2019 11:02 pm
Foe
 Foe
(@foe)
RE: Resin Odor
The biggest source of odor when I first got it was the fresh Acrylic from the CW1. An air purifier with HEPA grade filters + carbon pre-filter should also be able to get rid of odors.
Napsal : 28/10/2019 4:31 pm
kevin.e2
(@kevin-e2)
RE: Resin Odor
Posted by: @daniel-k5
This!
I bought a desktop air purifier off amazon.  It's about the same size as a CW1 and I have it running simultaneously with any print I'm doing.  It decreases the odor a considerable amount.
Napsal : 29/10/2019 12:00 am
Piet
 Piet
(@piet)
RE: Resin Odor
@kevin-e2
sounds good. Please, could you provide link and a picture of your setup? Thanks in advance
Napsal : 29/10/2019 5:02 am
Nils Anderssen
(@nils-anderssen)
RE: Resin Odor
I have made this box out of 3d pritned parts and plexiglass since I am using it in my home office and it almost solved the issue. It has a duct on the left side that goes directly to the intake on the left side of the printer. On the back there is a fan and a duct going to the window where I also have attached a fan to take care of the fumes appearing when handling the resin before and after the print. This reduces about 90% of the smell, but still smell a little bit and I cannot stay in the room for a prolonged amount of time. My guess this is because the solution in the window frame is not completly tight, but this is something I am working on. I am also looking into fitting a carbon filter or two on the duct going from the box to the window and maybe on the intake as well in case some air gets out that way.
A consequence of having the box is also that it reduces the smell when poring the resin into the tank is reduced because of the fan in the back.
I also think using a resin with less odor would be a good solution, but I do not have any spesific suggestions at the moment, but will try out a couple of alternatives in the weeks to come.
Napsal : 29/10/2019 6:47 pm
1 lidem se líbí
kevin.e2
(@kevin-e2)
RE: Resin Odor
Posted by: @3p-pietprintprusa
@kevin-e2
The setup is unremarkable, the air purifier is just sitting off to the side on the same table.  When I'm next to the printer I can smell the resin but a few meters away (where my desk is) I can't smell it.  The table is next to a window as well so I can always open that if necessary.
The device is here: https://www.amazon.ca/gp/product/B07PRTL8XR/ref=ppx_yo_dt_b_asin_title_o01_s01?ie=UTF8&psc=1
Napsal : 30/10/2019 12:06 am
1 lidem se líbí
