pad brim size wont change now
widget2k13
(@widget2k13)
hi, ive always been able to set my brim size on the pad to 0.1 minimum but since i updated it wont let me slice an object unless i have a minimum size of 1.6 which i dont want, is there a way to make it go back to 0.1 ?
Postato : 11/02/2022 9:59 pm
What size nozzle are you using?
Postato : 12/02/2022 1:16 am
widget2k13
(@widget2k13)
RE: pad brim size wont change now
hi, its a resin printer so no nozzle
Postato : 12/02/2022 8:17 am
Oops! this happen sometimes, something pops up in the feed and I don't notice which forum it's from...
IIrc the pixel on the SL1 is 0.047, fine settings always become problematic as they approach 2 - 3 times the finest possible.
Sorry for the confusion.
Postato : 12/02/2022 2:55 pm
widget2k13
(@widget2k13)
no problem 🙂
the problem i have is the bad below the printed item i used to be able to change that to 0.1 in size but now it wont let me change it below 1.6 since the update which is not what i want, looks like i need to go back to an old version 🙁
Postato : 12/02/2022 10:07 pm
