Mixing resins? What ratio do you use?
Wilko
(@wilko)
I've seen several posts with people mentioning that they have mixed resins, both to get a different elasticity or colour.
What kind of ratio do you use between flexible and normal resin to get the result of a non brittle print? What is that ration dependent on: harness rating?
I have ordered a kg of flexible resin, but considering the price per kg of that stuff compared to normal resin, it would be nice to not use more of it than is absolutely necessary.
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Posted : 14/01/2021 8:53 am
Lichtjaeger
(@lichtjaeger)
RE: Mixing resins? What ratio do you use?
25-30% Flex and the print is way less brittle and still hard.
Posted : 14/01/2021 9:52 am
Wilko
(@wilko)
@lichtjaeger
Danke!
Is the 25-30% range based on experimenting?
May I ask what brands of normal and flexible resin you combine?
I have Prusa, Anycubic and Sunlu resins, and I'm not sure right now what brand the flexible resin is that I have ordered.
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Posted : 14/01/2021 1:14 pm
Lichtjaeger
(@lichtjaeger)
Yes, experience values.
I use Monocure Flex100 in combination with Prima Value Standard, Prusa Tough and Monocure Rapid resins.
Some reference:
PS: Monocure does also offer pigment sets to dye your resins.
Posted : 14/01/2021 1:50 pm
Lichtjaeger
(@lichtjaeger)
If you use a usual flex resin instead of Flex100 you might need a 1:1 ratio or even more flex. One key factor is the shore hardness. Flex100 has 10.5D, flexible resins between 60D and 82D and standard resins 92-94D.
IMO 85-87D are good values for miniatures.
Posted : 14/01/2021 2:02 pm
Wilko
(@wilko)
@lichtjaeger
Thank you!
That video certainly is a nice example of someone putting some effort in experimenting with mixing resin *and* sharing the results in a very useful and compact manner!
Prusa MK3S
Prusa SL1
Prusa CW1
Anet ET5 pro
Anycubic Mono X
Posted : 15/01/2021 12:06 pm
