[Résolu] Tilted platform
karlos.v
(@karlos-v)
Tilted platform
HI
After my first succesful print test, the printing platform ended the process in a tilted position.  I tried turning on the printer again, I thought The printer would move the platform to its correct position, but it didn't work.  What do I have to do to restore the proper position?
Thank you
Publié : 25/09/2019 8:15 pm
RE: Tilted platform
Post a photo ...
Publié : 26/09/2019 1:32 am
karlos.v
(@karlos-v)
RE: Tilted platform
Ce message a été modifié il y a 7 years par karlos.v
Publié : 26/09/2019 7:47 am
RE: Tilted platform
You may want to contact Prusa Support using the store CHAT button.
Publié : 26/09/2019 8:31 am
karlos.v
(@karlos-v)
RE: Tilted platform
I have just talked to them through the chat.  Thay have told me it is normal, the position will be restored at the beginning of the next printing process.
Thank you Tim-m30
Publié : 26/09/2019 8:59 am
Milhooz
(@milhooz)
RE: Tilted platform
Yes happened to me as well but it was put back to the correct position when starting the next print.
I did not see it was tilted so when I filled the resin I went a bit over the max line but did not cause any problem.
Publié : 26/09/2019 10:17 pm
