SL1 Tilt Axis Check Failed
bdpope88
(@bdpope88)
Hello!
I am running the wizard and can't get past the first step. For my tilt motor, I receive the below errors. I'm curious if anyone else has received these? I disassembled the tilt motor connecting rod once and redid it to see if a difference happened and it didn't.
See photo descriptions for additional info.
Thanks!
Posted : 08/12/2019 6:50 am
ruedi.k
(@ruedi-k)
RE: SL1 Tilt Axis Check Failed
I have just configured the printer and now the same issue appears as in the first Picture or sometimes the error message "Tilt end stop not reached!". I have not found an solution yet. Is there a way to check the optical sensor?
Posted : 08/12/2019 10:05 am
Kiwi
 Kiwi
(@kiwi)
I had the same problem. I realized that the wire that goes from the optical sensor to the board is not the same at both ends. So I flipped the wire around and everything worked. Maybe I missed it in the instructions.
Posted : 25/01/2020 4:07 am
