crash detected only when printing with 100% infill
Binaryinfections
(@binaryinfections)
so if I print normal ANYTHING, printer is flawless. but today I tried to print a part with 100% infill and it gives me a few crash detected and then it fails the print all together. anyone else has this happen?
Napsal : 14/02/2024 12:05 am
RE: crash detected only when printing with 100% infill
100% infill is sometimes an issue...
Try printing enough top and bottom layers to prevent infill, and you will get a better print.
Napsal : 14/02/2024 9:07 am
1 lidem se líbí
miroslav.h4
(@miroslav-h4)
It is so. 100% filling does not solve anything, the filling should be a maximum of 40 - 50%, no more. The strength is made by the perimeters, easily 4 or more if there is room for them, then add the lower and upper layers. Alternatively, increase the temperature of the nozzle up to the limit of what the filament can withstand if it does not burn and degrade, easily to 230 or more in the case of PLA, the same applies to other materials. Next, reduce the printing speed so that the new filament has time to melt the already laid layer and connect with it.
Napsal : 14/02/2024 10:32 am
1 lidem se líbí
