Input Shaping
ChrisG
(@chrisg)
Miembro
Input Shaping
It is for me not clear if the MK3.5 handle input shaping or not.
I follow the YouTube from Chris Basement. When I look to the result than the quality is perfect.
When I compare to the result with the result of Chris it look like it does not have input shaping.
Who know the answer
Respondido : 14/06/2024 8:00 am
Matze
(@matze-3)
RE: Input Shaping
HI, for me it looks like the Mk3.5 have no IS. Because when I check the .gcode for Inputshaping the Value for F=0
M593 X T2 F0
M593 Y T2 F0
https://help.prusa3d.com/article/input-shaper-mk4-s-mk3-9-mk3-5-xl-mini_451816
Respondido : 09/09/2024 7:42 am
jimmy
(@jimmy-2)
RE: Input Shaping
Oh yes is has. You could disable the input shaper in the menu and set it at "null" at both axis. You could hear and see the difference. I calibrated mine using the accelerometer which gave me extra quality and lesser ringing/ghosting. My x-axis gave me 35hz instead of the prusa standard value of 50hz, the y-axis was the same. I am using the lastest alpha2 firmware btw ;o)
Respondido : 18/10/2024 6:34 pm
jimmy
(@jimmy-2)
RE: Input Shaping
the darker line you see is I raised the temperature during print to see what it does with petg. printed @speed profile .20 layer 0.4 nozzle, volumetric speed 12.
Respondido : 18/10/2024 6:42 pm
