Z-Axis Test fails after 3.5 upgrade (first layer and printing flawlessly - annoying Test fail reminder
Clamikra
(@clamikra)
After having updated my 3s+ to 3.5 everything is fine and after some minor adjusting issues it only keeps on constantly failing z-axis test.
that does not bother me to much as the printer prints perfectly and even MMU3 prints well (after I understood some changes in the way it works now).
I tried quite a lot of changes to get the z-axis test passed. I even went into the secret configuration menu and experimented with different values for z-axis length with no effect (so I got back to default).
In the test the z axis goes up to the top like normal and after the usual ugly noise on the top it starts  going down to 50mm and moving x-axis. Two green x-es for x and y.  After that it goes down to zero with just not touching the build plate (as it should). Than the Extruder goes up some centimeters and gives red x failing to complete the z-axis test.
any ideas what else I could try to get the z-axis test passed?
- I tried test with and without building plate
- I tried with and without nozzle (revo six)
- I flashed the actual firmware again.
Or is there a way I can switch off the anoying reminder about not finishing all configuration tests. I understand the intention of this message but if the printer works fine and I know there is no error but possible small deviations from factory values,  then I wish I would be able to permanently switch off  this message on printer startup.
Respondido : 02/04/2024 9:14 pm
Clamikra
(@clamikra)
RE: Z-Axis Test fails after 3.5 upgrade (first layer and printing flawlessly - annoying Test fail reminder
Solved
after having installed firmware 6.0 all tests pass.
by the way, firmware 6.0 is great and touch option a nice surprise!
Respondido : 19/04/2024 8:28 pm
Felix Andrea
(@felix-andrea)
Miembro
I also encountered the same problem after upgrading to MK3.5. The most annoying thing is that the printer works perfectly but keeps showing Z-axis test error message. I tried re-checking the mechanical parts of the Z axis, but nothing unusual. A temporary solution I found is to skip the Z-axis test in the settings if everything else is working fine. Does anyone have any other suggestions?
Posted by: @clamikra
Solved
Respondido : 23/10/2024 3:51 am
