Another Z-offset Calibration Help Request
I moved my printer, re-ran the wizard, and now can't get the Z-offset right. I've been everywhere from -0.275 (pictured) to -1.250, which was obviously too low. It was starting to blob up and pull off the plate as a weird mass starting around -0.5. Any thoughts of at least which way I should go? Thanks.
Publié : 19/02/2024 3:28 am
What has happened to that build sheet? Is the other side in better condition? Get it really clean - dishwashing detergent and plenty of HOT water.
Then dry your filament.
You're right, you have nowhere near enough squish, the corners are not staying in place, it needs to go lower.
Run the first layer 'Z' offset calibration again and show us one that you think is getting too low; we need to see the whole print on the print-sheet.
Publié : 19/02/2024 12:04 pm
