mmu3 bondtech adaptation
craYzjoe
(@crayzjoe)
hello
I'm trying to adapt my bondtech extruder to work with my new mmu-3 .
do I use the old setup?
Opublikowany : 15/12/2023 4:08 am
joelarimore2
(@joelarimore2)
RE: mmu3 bondtech adaptation
I'm doing the same thing, have it mostly working, put the bottom half of the "new" chimney over the filament sensor that has the tube threads on it.  The filament needs to load about 5 mm more LOL, I think the old filament sensor location doesn't work, I'm looking at how to change the loading procedure to give it a little more.  Let me know if you got yours working!
Opublikowany : 29/03/2024 9:28 pm
Arabidopsis
(@arabidopsis)
You are trying to get the Bondtech BMG to work with the MMU3, right?Did you manage it?
Opublikowany : 14/05/2024 10:14 am
montejw360
(@montejw360)
not much action on this thread. bumping it up as i would like to know if it's possible to use a bondtech bmg extruder.
thanks
Opublikowany : 04/08/2024 11:00 pm
Onno
 Onno
(@onno)
I am considering using a Bondtech i3 extruder with my MMU3 as well. What are your experiences?
Opublikowany : 13/03/2026 6:05 pm
