Mmu3/2 setups
Stránka 2 / 2
Rainer
(@rainer-2)
RE: Mmu3/2 setups
Some people use a small weight to make up for gravity. I have already seen something like this on printables.
I also had a setup with an extra buffer which worked without any problems. Out of curiosity, I have now put the buffer together. Thanks to the possibility of loading the filament with the buffer fork without removing the rollers, I have also found a place for the buffer.
It works both ways. It always depends on how much space you have. In my case, the printer is in a cabinet and the filament is above it. There has to be some kind of buffer in between. If you have space behind the printer, Joan's option is certainly a good one.
Napsal : 21/06/2024 7:14 am
Witties3D
(@witties3d)
RE: Mmu3/2 setups
With weight
Napsal : 21/06/2024 7:25 am
PFA
 PFA
(@pfa)
RE: Mmu3/2 setups
Thank you for the replies. I still need a few more days to get it all squared away. I will report back when I have it working and let you know how I did. Thanks again.
Napsal : 21/06/2024 4:01 pm
PrintingD
(@printingd)
RE: Mmu3/2 setups
MK4/MMU3 - I have tried several setups. Latest iteration has the buffer sitting with the cassettes vertically, and then the standard filaments holders sitting on a shelf above. The upshot here is that I can easily load/unload, and smaller form factor.
I still think that taking the cassettes in and out for loading and unloading is really annoying, and it dissuades me from printing more, but the current setup is OK.
I would love to hear about :
1) Reasons to be concerned about orienting the buffer with the cassettes pointing UP. (seems ok? but I have not printed much yet)
2) Ways to make loading faster/easier.
2) Ways to load filament faster and easier.
Napsal : 26/06/2024 2:59 pm
GerryPB
(@gerrypb)
RE: Mmu3/2 setups
The spools on a shelf behind the printer has been working for me. I still use the buffer too.
Napsal : 07/07/2024 3:22 pm
PFA
 PFA
(@pfa)
Tried this reply twice on my phone with no success, so let's try again here on my computer.
I ended up going with an old TV stand I had here. It is the perfect size and even has storage below. So, it is working out great. I also ended up using the spool holders that come with the MMU. Since I have space next to the printer on this TV stand, that is working out fine as well. I originally installed a bar above and was planning to hang my spools, but then I realized I did not have any more of that tubing and that the extra distance would have required it. I was planning to take a trip over to the local home store to buy some, but honestly, this setup is working fine, so I think I'll just leave it as-is. I did keep the bar above for loose filament that is not on a spool. I have some of that and while not my favorite to use (because it always tangles) I don't want to get rid of it. So, the bar above at least makes it manageable.
This post was modified před 1 year 2 times by PFA
Napsal : 07/07/2024 5:31 pm
Mr. Painless Potter
(@mr-painless-potter)
RE: Mmu3/2 setups
my mmu3 setup almost finished exept the the end design for the two side glas panels, wich will remain slideable and easily removable. I used 2020 profiles for a half open enclosure, to protect against draft and prevent warping. I mainly print PLA and PETG, and love keeping things easily accessible.
all my design from scratch, spoolholder with ball bearings...
Napsal : 21/07/2024 10:29 am
Hello
(@hello)
RE: Mmu3/2 setups
Posted by: @pfa-2
Id recomend the loading fork and printables its amazing and makes life so easy
Napsal : 26/07/2024 9:39 am
1 lidem se líbí
InfillTech
(@infilltech-2)
RE: Mmu3/2 setups
Here is my rather compact setup:
Spools on top of a shelf, Buffer on the side of the printer with buffer cassettes oriented upwards for easier access. I used to have the Buffer mounted on the wall underneath the shelf, but that caused way too much friction and thus issues with colour changes. Current setup works flawlessly.
Napsal : 19/08/2024 4:33 am
Stránka 2 / 2
