Not wiping with filament change for support color.
Lisa Zark
(@lisa-zark)
I have a recessed lettering I want the support color to match, while the rest of the print is the main color. Extruder 2 used for main, 3 for the letters (all PLA). This is a face down print flipped would require way more support material of extruder 2.
In Prusa slicer I set support material to extruder 3 and the print starts with extruder 2 for the main part, then moves to the letters, switches filament to 3 and tries to print without anything coming out. It never started the wipe tower. Using 2 for supports leaves undesired color marks on edges inside the lettering.
What setting do I need for it to use a specific extruder for supports AND have it wipe during the change?
Any advice appreciated. 💕
Opublikowany : 10/08/2024 4:00 pm
Lisa Zark
(@lisa-zark)
RE: Not wiping with filament change for support color.
P.S.
MK4 with MMU3, Prusa Slicer, all latest updates and firmware.
Opublikowany : 10/08/2024 4:02 pm
Lisa Zark
(@lisa-zark)
Well I realized the Wipe Tower was turned off. But to turn it on it changes support material back to 0 which is use last extruder, which is the wrong color. Why can't I choose the extruder I want AND get a wipe tower. All PLA, no water soluble. If I do want to use water soluble do I have to make a different tower?
*frustrated* 🫤
Opublikowany : 10/08/2024 4:44 pm
Make sure you set an exruder for everything, leave nothing on default...
Opublikowany : 11/08/2024 12:32 am
