Your first layer 'Z' offset calibration might be a little low but it's hard to tell because your build sheet is filthy.
Clean the sheet with dishwashing detergent (Dawn/Fairy) and plenty of HOT water, rinse well and dry with a fresh paper towel. Handle by the edges only.
Then re-run your calibration with freshly dried filament and show us the result on the build sheet as above.
Opublikowany : 07/10/2024 8:47 am
