MMU3 Buffer Hardware
Nicognac
(@nicognac)
Hi! I’m looking to upgrade my buffer after purchasing a used MMU3 (it came with the MMU2S buffer) but I can’t two components:
1) the bearings for the wheels in the cassettes (no size is listed)
2) the pins for the bearings in the cassettes.
Is there a hardware kit I can purchase somewhere?
Opublikowany : 19/05/2024 4:04 pm
Nicognac
(@nicognac)
RE: MMU3 Buffer Hardware
Also the Collets! Where can I find the colletes!
Opublikowany : 19/05/2024 4:26 pm
Embedded Bowden Coupling for Metal
https://e3d-online.com/collections/all-spares
Opublikowany : 20/05/2024 9:31 am
Nicognac
(@nicognac)
Awesome thanks! What about the bearings and pins. Any ideas?
Opublikowany : 21/05/2024 7:34 pm
Dare I say RTFM...   Lol
https://help.prusa3d.com/guide/7-cassette-buffer-assembly_381796
Bearings type 693 - 2RS
Pins 2.9x8.5mm  (you can probably print these)
Opublikowany : 21/05/2024 8:11 pm
Nicognac
(@nicognac)
Thanks for the reply! I saw the manual but I thought that 693 - 2RS bearings come in multiple sizes! Are these the 3x8x4mm ones? Thanks for sharing the pin file!
Opublikowany : 22/05/2024 8:06 pm
to be honest I have not looked at the dimensions of the bearings themselves.  3X8X4mm sounds reasonable
693 is the bearing descriptor,
2RS means 2 rubber seals (you can get open ball bearings, rubber sealed bearings and metal shielded bearings)  Prusa chose rubber seals in this case.
Opublikowany : 22/05/2024 8:11 pm
Saphir
(@saphir)
I opened mine for you and measured them. Yes, the bearings are 3x8x4.
This post was modified 2 years temu by Saphir
Printing PLA and PETG at the same time? See the Guide for MultiMaterialSupports ----- Ejecting Buffer cassettes is not satisfying? May the Fork be with you!
Opublikowany : 23/05/2024 6:51 am
Nicognac
(@nicognac)
That was extremely kind of you to do. I just ordered some on eBay. Thank you!
Opublikowany : 23/05/2024 11:59 am
