MMU3 Buffer Hardware
Hi! I’m looking to upgrade my buffer after purchasing a used MMU3 (it came with the MMU2S buffer) but I can’t two components:
1) the bearings for the wheels in the cassettes (no size is listed)
2) the pins for the bearings in the cassettes.
Is there a hardware kit I can purchase somewhere?
RE: MMU3 Buffer Hardware
Also the Collets! Where can I find the colletes!
Embedded Bowden Coupling for Metal
https://e3d-online.com/collections/all-spares
Awesome thanks! What about the bearings and pins. Any ideas?
Dare I say RTFM... Lol
https://help.prusa3d.com/guide/7-cassette-buffer-assembly_381796
Bearings type 693 - 2RS
Pins 2.9x8.5mm (you can probably print these)
Thanks for the reply! I saw the manual but I thought that 693 - 2RS bearings come in multiple sizes! Are these the 3x8x4mm ones? Thanks for sharing the pin file!
to be honest I have not looked at the dimensions of the bearings themselves. 3X8X4mm sounds reasonable
693 is the bearing descriptor,
2RS means 2 rubber seals (you can get open ball bearings, rubber sealed bearings and metal shielded bearings) Prusa chose rubber seals in this case.
I opened mine for you and measured them. Yes, the bearings are 3x8x4.
Printing PLA and PETG at the same time? See the Guide for MultiMaterialSupports ----- Ejecting Buffer cassettes is not satisfying? May the Fork be with you!
That was extremely kind of you to do. I just ordered some on eBay. Thank you!
