MMU3 + Bontech LGX extruder issue with feeding the filament
Rob
 Rob
(@rob-19)
Miembro
Hello everyone,
The MMU3 is driving me nuts, like many people here. I will try to explain the issue I have as clear as possible:
I have the following setup Prusa MK3S+ + Bontech LGX extruder + MMU3—all with the latest Firmware.
The filament loads into the idler and then when I press in Prusa's menu " load to extruder" the filament flows down into the extruder, but, as soon the IR sensor detects the filament, it stops right there and it won't reach the gears of the extruder.
Here is a video that I sent to prusa's support team: https://drive.google.com/file/d/1C8j55J3eP4O-cfLHibJ8Dp6aEhvKDgem/view?usp=sharing
I have 2 theories,
  1. the IR sensor is messing with the code
  2. I must change the parameter M701 (load filament) in the EEPROM.
in case you think it is the case 2, I am not an advanced user so I would appreciate it if somebody could explain, step by step, how to modify the EEPROM. I have seen a lot of videos and read many forums, but they skip steps and I get stuck. I have managed to install EEPROM editor in Octoprint but it doesn't show too many options:
Thank you very much in advance.
Best Answer by Volker:
try:
M708 A0x0b X25 ; extra load distance
in the custom G-code of the printer settings.
Respondido : 03/10/2024 7:17 pm
Volker
(@volker)
RE: MMU3 + Bontech LGX extruder issue with feeding the filament
try:
Respondido : 04/10/2024 12:12 pm
Rob
 Rob
(@rob-19)
Miembro
THANK YOU!!!
it did work. You can't imagine how many hours I've spent trying to figure it out. Really really appreciate it!
Respondido : 07/10/2024 12:09 pm
ddl.vnt
(@ddl-vnt)
Miembro
Hi Rob, which hot end do you have?
i also have a MK3S+ with an LGX and a shortcut mosquito but apparently bondtech says it's not compatible with MMUs. What software did you run on the printer? i'm really interested in adding the MMU3 on mine. Thx
Respondido : 14/10/2024 7:14 pm
3d-gussner
(@3d-gussner)
Reputable Member Prusa-Translations
Please use the correct printer firmware as you have the stock firmware installed.
Here some links which should help you to get the correct one:
https://support.bondtech.se/Guide/00.%20Bondtech%20Prusa%20i3%20-%20Firmware%20Update/44.html
https://www.bondtech.se/knowledge-base/firmware-updates-for-prusa-i3/
Respondido : 15/10/2024 6:25 am
